Where To Find?
I asked a dealership and the only OEM chrome tips available are for the 5.3L; I've googled 6.2L exhaust tip and can't seem to come up with anything. Does anyone have a link or source for a chrome exhaust tip for the 6.2L?
Actually while I'm at it does anyone know if there is a dual exhaust OEM or aftermarket available? Not for performance but just sound and looks....
try gm perfomance parts. corsa has a kit. and one can be made with the muffler you want
Check Magnaflow #35213, its a 14 1/2" polished SS tip with a 3 1/2" inlet clamp on style.
Jegs has tips from several companies that fit the 6.2 exhaust, just type in the tip diameter to locate what you want. www.jegs.com
Also there is a GM accessories chrome tip for 6.2L trucks, #19170728. List price is $125 CAD.
$125 for a tip?! If anyone pays that all I wanna know is if they used vasoline first! :D
When I get my truck, I may try and polish it..... Not sure if it will work or not, but maybe :D
the tip is 3 3/8" IIRC, looked into it. :D
I like how mine looks stock, but if somebody pulls up behind me i can send them a message to stay back. :D
Bought this last yr for mine. Paid like $70.
Sorry about the glare in the photo.
  • 2 months later...
Hi Ryan,
Do you recall the part # of this tip?
I can find two GM acc. tips. The longer one is the part number that somone mentioned above. It says it is for a Escalade or Yukon and is part #19156357. The one you have I believe is the short one. Part #19170728
Likarok
OE Exhaust Tip - Dual Wall, Angle Cut, Highly Polished, For Use on Crew Cab Models with 6.2L (L9H) Engine 19170728
im going to polish mine in the spring....i think the chrome Gm one looks out of place (sorry Ryan, I love your truck but hate the tip LOL)
I love Ryan's dog. My 3yr old pure breed yellow lab, Katie, would love to play with him. :(
She LOVES to go for a ride in the truck.
    ballencd
    ballencd
  • Who's Online   6 Members, 0 Anonymous, 685 Guests (See full list)
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
    • $5.19 for regular...
