Anyone Wanting To Change Gauge Cluster Leds, Lemme Know
what about white numbers and red needles on an 07 lt, and how much?
The numbers would be the only LEDs needing to be changed, the needles already have red LEDs behind them. Still trying to come up with a pricing.
blue numbers and white needle on an 04 sle
Your truck is a totally different ball game, your gauges use regular light bulbs that are soldered in unlike other older model cars that are simple twist in. The guy at www.blackcatcustom.com is working on a complete mod for your truck model I think, still in the works tho
I did a few of the 03-06 clusters, I even did a write up on here about it.
http://www.gm-trucks.com/forums/index.php?...=120885&hl=
Scotty's the man! :D
He has done several LED upgrades and does excellent work as well as being very meticulous with attention to detail.
x100 :bs:
Once I change my 4 gauge cluster to the 6 and order my gauge face and LED's from black cat then I'll have to get you to change it out for me. It'll be even easier since you live in BR
I live near Alexandria but my sis goes to LSU so I do go down there regularly on weekends so we could schedule the swap out down in BR whenever you're ready since your truck needs to be cool to swap out the gauges also.
Sounds good to me. My truck isn't cool enough yet. But will be one day
The different combinations of what you can do to it is pretty broad as far as number colors and needle colors. I only have noticed my truck on here as far as swapping out LEDs so the picture variations are going to be limited to my gauge install. Link is below
2009 GMC Sierra Custom Gauges With New LEDs
can I keep everything the same except making the light(Numbers) white and will the background be black??? I like the red needles. Are the needles colors just determined by the blub using the same needles...?
You wanting to put a new gauge face in or not? The LEDs behind the factory numbers are the color that they show up (blue/greenish) the factory gauge face is white letters. The factory needles are red with red LEDs behind them.
