Wierd Noise Under Dash
tjewell71
Hi, I have an 05 GMC Sierra Z71 and when I give it gas I hear a noise almost like a bubbling sound coming from under the dash arround the floor board. Can anyone help?
Have you checked your coolant level? If you're low you can sometimes hear gurgling from the heater core
Just add coolant to the proper level. Simple as that. Wouldn't hurt to squeeze the hoses a few times to burp the air out after you fill it up, & run it with heat on high.
A few heat/cool cycles will get the rest out.
Thanks, I will try that.
I've had success filling through a disconnected heater hose. It goes directly into the core. Sometimes a pocket of air is hard to get out!
