Please Please Please
LarryE
All atv owners with kids
Please watch your children and do not let them ride alone without a helmet and proper attire.
My cousin is laying in cabel hunington right now with a major head blow,  road burnes, bulging disk, sprung wrist, and broke ankle.
He lost control and hit a drain pipe and the 4 wheeler and him did a 360 and head planted on the main road.
He is responsive, and loved the plane ride, but he got lucky  alot of kids do not.
The 4 wheeler is totaled but that is nothing but material
So please take care of your children, because I know it has opened my eyes.
Sorry to hear about your cousin.  He is in our prayers.  ATV's are not toys.  Parents of kids should not take them lightly.  Even though 4 wheelers are much safer than thier 3 wheeled predecessors, there still much risk in the hands of kids and the inexperienced.   :cheers:
Good post Larry.  I plan on making my son wear his everytime he rides it.  I did when I was little as well.  Back when I was in high school, a good friend of mine's brother almost died as a result of a w-wheeler accident.  To this day, he has no sense of smell, partial loss of vision in one eye, and some facial scars.
Hope everything goes well Larry.
Hope everything goes well Larry! Not sure if its the same in other places but the news of an ATV accident involving kids and adults is no surprise here in So. WV. To address Toms post, I feel that no matter what age, you should wear a helmet, not just when you are young!
And even when your older as well.  People may think they are older and wiser and and won't do things to hurt themselves, but accidents still happen even though you may be trying to be safe.
Again, back when I was younger and we had out ATV's me and Elwood's dad NEVER wore a helmet.  For years and years he rode with no problems, but one time after I came in the AF, he was riding with some friends of his, and while climbing a hit, he unexpectedly hit a root or rock or something.  It kicked the front tires of the ground and the momentum flipped it right over on top of him.  He said the hadle bar/headlight assembly landed right square in his chest.  He said he could hardly move and really thought he was seriously hurt.  Luckily he wasn't.  Had he been positioned a little differently, it could have been his face/head, which I'm sure would not have been good.
Safety first.  :thumb:
Sorry about your cousin. But maybe for others out there it can serve as a wakeup call.
Just remember that helmets, and saftey training should be used for a lot of sports. ATV's, Motocylces, dirtbikes, mountainbikes and snowmobiles. Play it safe, wear a helmet and learn how to operate each of these vehicles safely. You only get one life.
:cheers:  :chevy:  :)
Out of  curiosity how old is your cousin Larry? Hope he's doing better. At least you can be sure from now on he'll ride with all the right gear. Tell him that there is people all over the country pullin' for him.
I've had some close calls and a broken helmet to prove it.
Dude, I hope he's well or getting better.
I perfected much of my stuntwork on my old Polaris Scrambler.  :cheers:  But yes, I wore a helmet.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
