2009 Gmc Crewcab 4x4 In Ks
CLASSIC87'
I'm looking to sell/trade... no hurry either way. Here are some of the details:
- SLE
- 10,500 miles
- small lift
- Max Energy Power Programmer
- charcoal interior
- 20" wheels
- electric start
- Rhino lined
- Tonneau cover
- rear under seat storage
- catch all mats
- Billet grill
- Debadged
Much more but I think you guys all know what come with this trucks... obviously it is a very CLEAN/MAINTAINED truck... NO dents/scratches etc.
Looking to get in the mid $30's.
I will load more updated pictures as well as far as the exterior... the vent shades have been removed, side trim added, as well as chrome bed rails.
Thanks,
Anthony
316-640-5280
Good luck with the sale. I was looking at a truck like yours since I wanted to move to a 4x4, but they were only asking around $26 with cloth seats.
That's a really nice looking truck. May I ask what kind of lift it has? Also what type/size wheels and tires do you have on that? I like your running boards better than mine too. Good luck with the sale.
Thats a good looking truck. That would be hard to get rid off. Will keep my ears open of anyone looking for one. I live in dodge city.
Thanks guys for the comments... yeah it kinda is hard to get rid of... moreless testing the waters; which is another reason there's not a "set" price on it. The tires are Nitto Grapplers 305/55/20 with a lift of 2" (I think).
Gmowner4life: Please don't try and compare this truck to another truck that has cloth interior for 26K... no need.
Thanks,
Anthony
Do you happen to know where you got your lift at and what brand it is? I like a 2 inch lift but can't find one anywhere.
I can look into that for you... I do know there's a coil spacer installed and a block added in the rear (approx. 2").
Thanks,
Anthony
Thanks,
Anthony
Oh ok that might be how its done then.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
