Steering Backlash
jro909
say you hit a bump, the steering wheel will lash in the direction the wheel(s) is being forced in
uh 04 z85 1500 uh all the repairs were for driveline related stuff nothen with the suspension..tires are stock size 255/r16
120k miles, almost every gm truck i've driven does it, something about independent front suspensions don't have a steering stabilzer or somthen
Maybe a little shake, nothing that I've ever felt as normal that was violent though, in 14 years of working on them.
Check the front shocks. That's what causes most, what I call "head shake", issues.
brand new shocks man, when i say lash i me the steering wheel turns itself slightley in the direction the tires are forced to go because of a bump or pothole
That sounds pretty normal, in my experience. The problem I've come across mostly is where there is "deadband" in your steering wheel....thats about the best way I can describe it. You can turn your wheel an inch or so in each direction before it makes any difference to your direction of travel.
lustworm.......WTF are you talking about ..... if you hit something the force is gonna move something and if its your tire ....the steering wheel will move ,,,normal
