Taking your requests!! What do you want to know?
Zane
Hello all!
Tomorrow i will be picking up a 2003 Silverado LT, with Quadrasteer to test from GM's media fleet.
I'm taking your requests for pictures, more detailed information, etc..  :D
No magazine can give you this!!  :D
When I saw one at the auto show it was roped off so I couldn't crawl under it and look.
Who would have stopped you no one was around.  I got on my knees and got up by the ropes and got a great look under it.  People thought i was nuts (SO!) hehe
C'mon, I did that too, no one looked because no one even noticed that lonely chevy sitting there.
But, I want to make Zane crawl under it and take a ton of pics of it :D
Cause it was so ugly.  They put it in "Time out" hehe
and yet you were getting googly eyes over a blue '03 at the dealer.
See, you've grown to like the look of it, just admit it.
####, even i am starting to like it, not as much as the f-series of course  :cheers:
i would like to know about what kind of MPG the truck is getting and how quadrasteer holds up off-road
TOP SPEED! TOP SPEED! TOP SPEED TOP SPEED TOP SPEED! :cheers:
when you have it turned all the way one way or the other, and mash the gas from a dead stop, what happens exactly? It's gotta be a unusual feeling, right?
race a ford AND a dodge.
see if i8ts hold up better at higher speed in "twisties" :thumb:
Not really.  I hate the front end but I could live with it.  I think larger tires would make it look better the puny 245s were tiny
after seeing a sd with quadrasteer yesterday at the bank I was hooked... first time I got to see the 4steer in action and i almost poped a big one when it happened.
I'd love to get one and slap on some 22's.... sounds like a plan to me
i totally agree.  When i was pulling out of the resturant this evening, these teenagers in a nearby car caught the rear wheels moving and all piled to the window to get a better look. They were pointing and everything...  :cheers:
    • I went to order some PF63 oil filters from an on line GM parts source, and the blue PF63 oil filters seem to be getting phased out. They show the new part number as 19363567, which is a black colored AC Delco Silver product apparently marked PF63A. Some sites show a part number 12693541, which is a black colored AC Delco Ultragard Gold filter marked UPF63R.    I assume the UPF63R is the better one, but I’d be happy if I could just get blue PF63 filters I’ve been using.    Can anyone explain what is going on with the filter part number changes and any actual design changes?  Any other advice on buying OEM filters right now?  Thanks
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Will be attempting this sometime shortly and will likely make a youtube video out of it.   Note: please disregard fuse sizes. Main fuse will likely be 25A, all mini bus fuses will likely be 10-15A.   Here is my parts list: GM 84347199 - TC, Cargo Light, Exhaust Brake (useless to me unless I find a means to reconfigure), Aux 1 - 4. 12V 6 Way Pre-Wired Fuse Relay Box Kit with 4 x 40A 4-Pin Relays (link below - some mods required to make negative trigger)            https://www.amazon.ca/dp/B0F4KCS43B?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 Various wire sizes (12 AWG - red and black, 14 AWG, 16 AWG multi-colored bundle) Wire termination leads for X61A-X1 (unknown at this time) Crimp connectors/Soldering Gun Heat Shrink Split Wire Loom To be continued...    Cheers
