Fuel Octane 20x9
peterk814
Hey guys,
Just wondering if anyone had a pic of a black GMT900 with Fuel Octane wheels.
Also what size tire should i go with. its a 20x9 rim, would 275/55/20 fit? or should i go with a 275/50/20. I do not have a lift kit, but might possibly get a level in the future.
Thanks
The offset of the new wheel plays a big role in how much tire you can run. If you are considering a leveling kit in the future, I would definitely do that before you spent the money on new tires. Level kit will allow you to run a little larger without rubbing issues.
275 55 would be fine even with a high/low back spacing. These trucks seem to have more issues with the width of the tire due to the narrow wheel well up front. I have a level kit and can run a 275/65 no problem.... Just not much option for tires so i went with 275/60.
IMO i would not run the 275/50 as its not even 31 inches high. Especially if you plan to level or lift in the future. Its an odd size and would be expensive. Cheapest i found for a descent tire was 200 for Cooper Zeon LTZ's. In a 275/55 (since its a factory size) you can get tires from 80 bucks to 500 but you can get some descent tires for 160 to 200 and have options from what i quickly looked up.
Right now you can get the Rough Country kit for about 80$ shipped to you. Its easy to put on and you can run a 275/60 and it would look real good. Thats a 33 x 11 tire. Any bigger and you would have to run a 4" or 6 " lift. So its a common setup and relativley inexpensive.
If your rims have a 5" or better backspacing You could run them with the 275/60 no problem from what i have been told and have read in threads here.
Good Luck.
Post pics after you decide and get it together.
    • I do have the 8 speed.  Interestingly enough, after driving my truck for the past 2 days now, I have not had the clunking issue at all!  I am beginning to think it may have been suspension/leaf spring related, and somehow when the shop put my truck on the lift to do their initial inspection, it relieved some built up tension/pressure that was causing my problem.  I swear it felt I was a bull rider on a bucking bull the way the truck would almost rock back and forth slightly before the big thud/clunk when coming to a stop.  I am hoping I got lucky here and it's gone for good.
    • Bring it to discount tire. They do free rotations even if you didn’t buy your tires there. I didn’t believe it until I tried and they did. You can tip the employee if you would like
    • Best part of this video is how it resets expectations. Wonderfully done piece. It also made clear a few points I've made from day one. Detergent oils DO NOT KEEP A MOTOR CLEAN at the recommended or longer change intervals. They just get dirty slower than a non-detergent oil and there isn't spits difference between them on this point if they carry the DEXOS license. Great thing about the license that gets missed is it assures CONFORMITY even it that means a low bar.    One thing he did not talk about that I paused on an magnified was the condition of the oil ring separator. Besides a stuck ring a plugged separator and land drain back is huge when it comes control. We see in short order improvement in control IF that is the problem.    Another item I took exception to and he did not make plain was the condition of the timing chest and under valve cover having something to do with indicating piston cleanliness. Schaeffer's Oil makes that same omission in their million mile Ford video. I'm guessing he has never torn down a Red Line HP, AMSOIL SS motor that has been on that diet from the get. What he showed in the video was a good deal of varnish. Something totally absent in Peppers 165K cover off look. I smiled because he did his at the same milage.    He also makes the mistake of assuming oil temperatures in the pan are the temperature all over the motor even though he makes note of the piston being the hottest part of the engine. that baffled me a bit.    I can tell you from personal experience and witnessing teardowns of family motors that even oils of the 1960's would keep them squeaky clean when OCI's were 1500 to 2000 miles without exception. At 3K and above you get what he experienced and the longer you leave it the quicker to gets to the junkyard.    I think his is missing a opportunity not tearing it down again when he's done killing it. Time would be his only cost.
    • Very often the part number on the trim part is just for the vendor order/assembly plant and will not show up in the parts system.  They won't make a bunch of extra parts that were not ordered. Keep in mind, lots of these parts were made to be "just in time" parts meaning they were dedicated to a vehicles ordered and sequenced for assembly.       Also, trim parts will often say, paint to match.
