Chrome Bmf Wheels
jdubub
I have an opportunity to get some BMF S.O.T.A. in chrome 20x9 for an OUTRAGEOUS deal. My question is do you guys think they will look good on my truck!? I originally wanted the same wheels in black but my project manager just got them installed on his new fx4. what do you guys think? and can anyone photoshop the wheels on my truck? ive looked everywhere for a pic on a newer body style and all i see is black ones. Have any of you got a pic with the chrome BMF's on a newer white chevy/gmc?
Also on another note how much can i get for my factory take offs with the GM locking lug nut?
Well yeah they will look good. Those wheels look slick and have a nice lip. BMF probably sells 2-3 times as many black wheels as they do chrome, which is why you can't find any pics. As far as your stockers, I have seen wheels/tires listed for $1000. Don't know what they actually sell for though.
:cheers: im thinking about doing it im just picky about wheels without the $ to change them if i dont like them haha.
lets just say under $1300 :smash: . They bought them for a customer that wanted them on a suburban but they installed one and the guy didnt like them and went with others. the customer spends LOTS of money there so they said ok and stuck them in their shop. they have been sitting around for 4 months.
cool.... think i might do it. Im trying to find someone that will buy mine locally to help with the money to get these. Only so i can pay cash and get them this week.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
