Tire Size For Blazer
wierdo124
I'm not looking to get larger really, but wider.
Currently it has stock 235/75/R15s.
I want to know if i can fit 265/75R15s on it, or if not, how wide i can go. Just looking for more traction in the snow, without getting snow tires.
Getting a "wider" tire is the last thing you wanna do for traction in the snow, narrower is better. Funny you should mention that size tire as I have a 95 LT Blazer 4x4 that I just put 265/75/15 tires on it (on the stock rims)...I had them lying around so I had nothing to loose trying them. I'm a member of the "Blazer Forum" and they said they would not fit, turns out in my case they did though...only at full lock with the power steering chattering does one side rub the inner frame and vice versa when the wheel is turned the other way. This vehicle is "not" lifted either.
If I was to do it again and had to purchase tires particular "just for snow" I would get the factory size in a snow rated tire.
On a side note I can't give you an idea how well my tires handle in the snow as I have yet to drive it in any snow with them yet just on wet and dry roads.
Wider tire = more floatation, more contact area, more traction on snow.
More floatation??? You wanna float on the surface of snow??? The idea is to cut to the bottom for traction, narrow tire does this also providing more weight in the smaller contact area. I own 3 4x4 trucks and a 4x4 Rhino and have experimented with many tires. I do have very large tires on one of my trucks and yes it does go through the snow but I gotta say the other two with the narrower tread are better. Even my offroad Rhino likes a narrower tires in the snow.
I just did a google search and found endless articles backing up what I say, anybody else here agree with me... :)
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
