How To Clean Inside Of Headlights?
Okay, I finished the polishing the outside of my headlights & drl/ turn signals, but the drl lense haze was not cleaning up. I poked a rag inside and there is a significant haze on the inside of the lense. How do you clean that off?! There is no condensation or dirt inside, just this haze coating the inside. Very similar to the exterior haze I have polished off other vehicles in the past. 02 1500 ecsb.
Open the lens/housings but I always have problems with re-sealing issues. I'd just buy new housings if they're that bad.
You can reseal them, I have successfully, using clear marine silicone sealer. You can get a small tube at a marine supply store such as West Marinie.
You can bake open the housing at 275 for 10 minutes or so. Pull apart and clean out the groove as best you can of old sealant. Clean the inside of the lense, then put back together with some 3M window-weld (available at NAPA, etc.) in the groove and bake together again. Alternately, you can buy some new headlights as they aren't very expensive for your generation being an older one.
Greg,
I thought I remembered about sloshing something around inside the housing. It might be worth a try. I have heard of the baking them apart also.
I may just get new ones from 1aauto after I get Christmas paid for. That will be awhile though, so I guess I will wash one out first, then maybe bake it apart if the vinegar does not work well. Thanks for the tips.
War Eagle!
Babyhauler
Greg,
War Eagle!
Babyhauler
no prob man.
if you cant afford to get new ones right now, i wouldnt try the bake thing til you have the money for new ones, just in case. i'd hate to see you stuck with no housings if you tried it and didnt have good luck.
Be careful using anything too caustic on the inside of lights. The "chrome" surfaces can come off. It's a very very thin layer of chrome that is not intended to ever be touched.
