Whirring Noise After Diff Rebuild
alvocado
I had all of the bearings and seals replaced in the front differential on my '02 Yukon Denali this week and the repair addressed most of the front end noise I was experiencing. However, I'm still getting a whirring noise which is particularly noticeable between 30-40 mph and present up to highway speeds. The noise will quiet down when I leave off the gas but doesn't completely go away. The work was completed at the local GMC dealer using all GM parts with the following items replaced (quantity and part numbers noted):
(2) 15801507 Seals
(2) 15588312 Lock Diff
(2) 26041515 W-Bearing
(2) 12470318 Adjuster
(2) 9420095 Bearing
(1) 9413427 Brg Asm-R
(1) 12471590 Seal
(1) 12479162 Spacer
(1) 9418356 Bearing
I replaced both front wheel hubs and all three driveshaft u-joints this summer. Is there a potential issue with the differential work or should I look at something else? The truck has 141k miles on it.
sounds like they didn't set the gears with the proper amount of backlash. Very common. Take it back, before its too late..
Thanks for the quick replies. I'll get the truck back into the shop tomorrow.
    FiLo
    FiLo
  • Who's Online   5 Members, 1 Anonymous, 555 Guests (See full list)
