6 Liter Engine No Longer Flex Fuel?
I just looked at a 2011 Sierra 2500 with a 6.0 liter V8 and the engine does not appear to be flex fuel type anymore. I believe that the flex fuel 6 liter was standard on 2009 and maybe 2010 models? It the flex fuel engine at least optional now?
No Flex Fuel in the 6.0s in the 2500/3500s 07 and up.
The 1500 6.0s yes.................
Na,Not even in the 1500's was the 6.0 flex-fuel,I know mine isn't,although I wish it was.
I don't think the Hybrid's are flex-fuel,If it is it will have a Yellow gas cap and "Flex-Fuel" emblem on the tailgate.
yep, look for the yellow gas cap as a dead giveaway
my 2009 Sierra SLT with a 5.3L is not a flex fuel motor.
Here's one for ya.....My manual says my truck is flex fuel, but I have the normal black gas cap. Never used E85 as I have never seen it. 06 5.3L alum block. ???
The manual mentions flex-fuel because the 5.3 VIN code "Z" (RPO code L59) is E85 capable ....However VIN code "T" (RPO code LM7) and the alum.block 5.3 VIN code "B" (RPO code L33) is not.
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 901 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
