Truck Downshifts Hard When Braking
I just bought an 05 Z71 and I noticed that sometimes when I slow down and stop, I can feel the trnasmission downshifting. It feels like a someone is downshifting and letting the engine compression slow you down. The only thing is, Im not doing that. Its doing it on its own. My wife's Tahoe does it when in Tow/Haul, but she has the 6 speed. Ive got the 4 speed and Im not running Tow/Haul. Is that normal in the half tons. It doesnt really bother me, I just want to make sure nothing is wrong.
my 04 half ton does it also...its quite strange but its been doing it ever since i got the truck :)
It only does it when its cold. after it heats up I dont notice it so much. How long have you had your truck?
3 years...trans is serviced at the dealer also with no red flags
I started noticing that my wife's Tahoe also does it when not in tow/haul. Its just not as severe as when its in tow/haul. I guess it may be one of those things they did to aid in brakeing. Or maybe its one more thing to add to the list or wierd quirks that a GM vehicle has.
my 2001 does this too. it has always been there since i got it at 40k miles, but its now pretty rough at 85k.
i saw your other post about your rear end clunking, when shifitng to reverse and whatnot too, my truck also does this.
my trunk also clunks when going from drive to reverse or vice versa...has the 1st-2nd bump feeling when shifting..its always done it
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
