Help? Protective Covering For Foglights
:confused: I had one of the factory foglights broken by a flying rock and those things are expensive. Was wondering if anyone knew of a product that could be used to cover the foglights, something clear, a self-adhesive sheeting material of some kind. The foglights are not glass but a plastic or polycarbonate of some kind. There has to be something available.
There are probably 947,000 companies that will sell you the stuff.
WHOA! that is a lot of companies :confused:
There are def a lot of companies that make them. I used to spend a lot of time on the road for work and bought some from 3M for what was them my Grand Cherokee. You can buy sets for headlights, markers, and fogs. If I remember correctly, they were pretty reasonably priced. They also did not yellow which I was worried about. If you do apply these, I would be cautious about putting a higher wattage bulb in as they do hold the heat in a little more.
