08 Silverado Ft Diff Leak
cammohl
I got a 2008 silverado and the ft d/s axle seal seeme to be leaking. Truck currenly has 46k miles on it just curious to see if anyone else has had any issues with these and how difficult the job might be to do?
I have had both of my diff output seal replaced on the front end. Warranty item go see the dealer.
Thanks thought it might be out because of the mileage over36k currently at 46
had both sides replaced once at 10000ish, 35000ish and just recently around 65000ish
Even 65k mile ones were replaced under warantee??
Diff seals covered until 100K no problem
That's great I wasn't looking forward to doing that job in the winter thanks for the info
spoke to the dealer this morning it is covered under the 100k mile warantee. I think the 06 would also have the 5yr 100k on it as well might depend on when you bought the truck to get it covered
    • Did you ever get this worked out? Mike is doing the two start thing now too. This is after a new camera back in December.
    • I’m doing an experiment on a vehicle I don’t have much money in. I’m going by the premise that after they last 100K miles they were no mechanical problems with assembly. Or defects with the parts. With oil changes by the minder for the first 127K miles when I acquired it. I quickly went through low mileage oil changes then settled on 5k oil changes with close to 170K miles on the vehicle currently. I did have the option to turn off the cylinder deactivation. I didn’t on this vehicle because it’s in ECONOMY mode at least half the time. It should be a no brainer frequent oil changes are the key. The manufacturer gets away with the long oil changes with its severe service  maintenance. Just ask them what is normal.
