Decided to check for updates for my 2021 Silverado 1500, and the system showed no updates available. When I checked the build number, it looks like it hasn't been updated since it was new. Does this look like I'm missing a ton of updates?
Thanks
For anyone considering the M&R Automotive 40" SLIM Light Bar setup for the 2022+ Chevrolet Silverado 1500, here’s an install video showing how the behind-the-grille setup comes together.
It gives you a closer look at the mounting process and what’s involved in getting the 40" bar positioned and installed while keeping everything tucked behind the factory grille.
Hope this helps anyone considering the setup or planning to tackle the install themselves!
I can see them dropping the SLE trim line but the SLT trim?? I think that's a bad move, I know several acquaintances that always buy SLT trim, usually every 3-4 yrs. They would never consider an AT4 (older) and the Elevation is a cheap model in their eyes.
I assume I'd be opening up pandora's box if I tried to source the early WT mirrors and tried to get the 2500 bases fitted to the rest of the 1500 mirrors...
