2007 Classic Adding Heated Turn Signal Mirros
:shakehead: Have a 2007 Classic, ie a 2006 body style. Have the power mirrors, windows, locks, but that's all. If I add a set of mirrors either with heat and/or the turn signal option is there a good chance any added wiring is right there in the harness to just plug in - that is are the connections already there? Any Body control module programming.
Thanks for any tips
Mike
:D Have a 2007 Classic, ie a 2006 body style. Have the power mirrors, windows, locks, but that's all. If I add a set of mirrors either with heat and/or the turn signal option is there a good chance any added wiring is right there in the harness to just plug in - that is are the connections already there? Any Body control module programming.
Thanks for any tips
Mike
Turn signals, yes. wiring is there but you may have to tap it if it does not plug and play. as for heated...got a button on the HVAC for anything...or even better - got a photo of your HVAC control head?
It is really easy to add them to a 2006, all you need to do is get a set of mirror that come with turn signals in the mirror. Plug them in and they will work, I did this on my 2006 Silverado and they worked perfectly. I don't know about the power fold, I never tried to activate that feature.
I put the Heated powerfold turn signal mirrors on my 06 a couple of years ago. It's basically plug and play. the mirror heat is activated by your existing rear defrost button. For the power fold function you have to replace your mirror switch with the one specific to the power fold, I think it was about $60.00. It's pretty easy.
Yeah, it was an easy mod to do on 2006 Silverado. I never activated power fold though.
