Which billet grill is better, the aluminum or stainless steel grill? It's the overlay type for a 2011 Gmc sierra cc. Just wondering which one will last and look better longer.
My Carriage Works billet is a couple of years old and still looks new. CW grilles are high grade aluminum. A lot of the "Ebay" grilles are soft, cheap aluminum. BIG DIFFERENCE!
Carriage works makes one of the best. I had one on my 03 and in 5 years, it still looked as good as it did new. :D
my ford explorer is wearing a cheap aluminum ebay grill for the second winter now and it still looks brand new but in the end you get what you pay for. id say go with the ss version, aluminum grills like aluminum wheels are gonna take damage from the salt on our roads, so if funding permits id say ss.
Skip it along with chrome door handles and gas door. My 2¢
Yeah man. Keep that cheap plastic grille so you look cool! :rolleyes::P:P:lol::lol:
