Stuck: Which Wheels To Go With
mc7719
Hey guys. Currently I have the GMC 20" rims, which, I love the look of (but not a fan of "lower profile" tires). However, that said, I use my truck to tow a 6000lb travel trailer (maybe 3-4 times a year) and do take it off road (a bit, nothing crazy) once in a while (logging roads, and the such).
I have heard the 17" are better for both of those purposes, as well, the tires are less expensive. I would have more options in sizes AND in treads (All-Terrains), since I have the RC 2" level to install, and will be going with a 33" tire.... but I DO love those 20's... what do y'all think??
My truck (currently)
And these are the 17" wheels I would be interested in going with (just web pictures)
I have heard the 17" are better for both of those purposes, as well, the tires are less expensive. I would have more options in sizes too, since I have the RC 2" level to install, and will be going with a 33" tire.... but I DO love those 20's... what do y'all think??
MAJOR down grade going to 17s from 20" OEM.. i think nearly everyone would agree
KEEP the 20's. After you factor in the price of buying the 17" wheels and the little bit of money you will save buying tires for 17's and not 20's........you may never save a dollar in the long run!!! Unless you sold your 20's which you will probably regret.
Is there a limit to only owning one set??? Cause if there is..... you should see my basement.
Whats the point in owning more than one set at a time?? then you end up with a bunch of sets that are all getting outdated at the same time.. I would much rather replace them every year or two with fresh designs..
If your just refering to keeping OEMs and having an aftermarket set and swapping them for winter then ya thats normal..
All personal opinion - there is not a correct way to answer this. However, right now I have 4 sets of wheels (winter steelies - spring/fall 20" OEM both in alum (clear and polished) / plan on dumping one of these sets soon - and my summer wheels). But thats just me.
I would have to say that majority would say to keep your 20's because of appearance, but I also see you wanting 17's for functionality, That is my reason for my Summer/Winter setup - I just threw another into the mix.
whatever works i guess
I personally wouldn't have 20's on a truck. 18 is max for me, and the 265/70-17s I have handle loads well (same wheel as you're considering). I use it as a truck, and I want plenty of rubber to handle the stress. I was specific about this when buying. Looks are "all opinion", but function isn't.
Sounds like you answered your own question. Rule of thumb for offroad is that you want at least half of the tire height to be tire and not rim. 20s are fine for the pavement pounders. Me personally, I hate the the 20s and up, they are butt ugly, but to each their own. JMO
I like to have a little more rubber around the rim, so I went with 18x9. I like 20" wheels on some trucks, they just aren't practical for the way I use mine. I just sold a set of the 17" wheels you're looking for last Wednesday, $200. You should be able to pick that wheel up pretty cheap. Good luck
I'd keep the 20's. Here's what you do.
1. Add either a 2' leveling kit or a '3 BL
2. Buy some 33' tires or larger tires
This guy did it and his truck looks great! Newer 20's but still GMC 20's.
But it's up to you.
Trade me!!! I have 17s and 285s!!!
I would consider it if you had the 17's that I want.... (and you lived closer lol!)
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
