09 Sierra 4wd Hard To Engage
Well fellas, as the title says, I have the floor shift 4wd in my 2009 GMC Sierra. Last year during the first winter I had the truck, I could literally reach down with 2 fingers and pull it back into 4wd. This winter, for what ever reason, getting the truck into 4wd for the first time of the day is difficult to say the least. I'll be cruising down the road and decide that I want 4wd, and try to shift into 4wd. Some times I can not get it to shift at all until i come to a stop and put the truck in neutral, then it will shift.
I've checked all tire pressures to make sure they are equal but this didnt change the effort of shifting. Something has definately changed from last winter, because it never used to be this difficult. After I get it shifted into 4wd for the first time, it will go back into 4wd much easier the 2nd, 3rd, 4th, etc times. Any suggestions?
lube the linkage.
Def sounds like the linkage needs some lube. More than likely theres some corrosion. Rust somewhere causing it to hang up. If that doesn't fix it then I'd wheel it back to the dealership.
They still make floor shift? :lol: I thought that went out with Jimmy Carter.
Push buttons are for girls, Real men have sticks........ :)
Guess I'm a girl. Love my push buttons.
Guess I don't have a real truck either. I have spark plugs.
Larry
Ice could be forming on linkage. Once you break it it would be ok. Also make sure you are rolling and not under load.
I dont believe it to be ice buildup, but I guess anything is possible. If I am not moving it will shift easily. The problem arises when I want to engage on the fly, say at 50-60 mph. Constant throttle, decel, accel all yeild the same results, no shift or a very difficult shift. Then as I said before, once I get it to shift the first time, it will be fine the rest of the day.
I do have an appointment with the stealership on the 15th, but I'm guessing they are going to tell me that "it is normal" or "we could not replicate the complaint"
All I know is that last year I never had a single problem with it at all, and now if I dont put it in 4wd before I leave the driveway, its a craps shoot as to whether or not I'll have 4wd when I want it later on in my trip.
For anyone who is interested in this topic, the dealership looked at my truck today and found a bulliten on this issue. Basically the bulliten says to replace the front diff fluid. The service writer and myself both are highly skeptical, and I will not know if it worked or not until the temps get cold again.
At the very least I got the fluid changed in the front axle :smash:
    ballencd
    ballencd
  • Who's Online   6 Members, 1 Anonymous, 667 Guests (See full list)
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
    • I'm putting in an A-pillar pod/gauges, and I'm asking if anybody can identify a (preferably) fuse for a switched power and illumination circuit on the driver's side interior fuse panel. Offhand, everything I checked with a test light was constant-hot, and I'd much rather uses a piggyback fuse. I can certainly find a wire, but I'd rather not half-tap.   Thanks in advance for any help.
