New Rc 2'' Leveling Kit
I'm very happy with the RC 2'' me and my father-in-law installed yesterday. I went with the method of disconnecting the sway bar and removing the bottom strut bolts to install it. Lining up the holes was tough, and there was a fair bit of swearing, but it got done.
I'm convinced that any project that starts in your driveway ends in the dark, no matter what.
Looks good...We need a before and after pic though
Unfortunately I don't have an picture taken at the same angle beforehand, but here goes:
BEFORE:
AFTER:
The weather is much better now too.
Even though they arent at the same angle, you can still see how much it better it looks now.
:lol: . I know this all too well.
I also took those annoying 4x4 stickers off the sides yesterday, no photos of that yet, I need a little goo gone to make them totally disappear.
What is it with those stickers? All Ford & Chevy pickup trucks have them. Is there a good reason why?
    Brendan C
    Brendan C
  • Who's Online   5 Members, 1 Anonymous, 1,163 Guests (See full list)
