Driver Window Will Not Go Up At Times
Hello all,
We have a 2002 Suburban 1500 vehicle. Somestimes the drivers side window will not go back up when the raise button is pushed. When it does this we have to hit the button repeatly and the window will finally go back up. Most of the time the window operates as designed. Where do we start? I suspect the switch itself. Is it replaceable? How do we replace the switch? Please Help!
I am fighting this battle with my 99!! First thing I changed was window motor put new one it and it worked 4 or 5 times before it would not work, I could slam door sometimes and it would work, so I thought it must be switch, so I ordered one and replaced it, after working on it a time or two you leave the window out of the track to make it easier to work with and after putting the new switch in it worked so I started to raise it to put the window back on track and it will not work at all now. Using trouble light I can make the other window go up and down, but not drivers side. I can find other hot wires to the switch panel but dont know where they go and have not found a digram for it yet. Good luck if you find anything let me know. :lol:
If you suspect the switch, try swapping it out with one from the other door(s). It might take some creative engineering, but they usually fit just for a simple test. I have done this numerous times with GM cars. If it works, then you know it is the switch, and you can replace it accordingly. If it doesn't, start looking at the regulator/motor and related wiring.
  • 1 month later...
Thanks for all the helpful information. Does any one have any idea on how to
disassemble the door panel to get to the switch panel in the arm rest? I have
not done this before and would appreciate any help that you might be able to
give us.
Thanks, in advance, for all your help!
ckbrownla
A lot of the time on higher milage vehicles (a relative term). Vehicles where the doors have been open and close a lot. You can have a broken wire inside the boot between the door and the A pillar. Have repaired quite a few with a these.
