Build Sheet
I am new to this forum.
I hope you can help me since my local dealer won't.
I need a build sheet for my 2000 GMC Sierra 1500 SLE
1GTEC14T9YE265148
Thanks for any help you can give me.
walter
The comp nine web site will give you all of the production options used on your truck. What more do you want?
For an actual build sheet printed out you need to go to a dealer.
The sites listed in the above links will give you the options your truck has (same as build sheet)
    Brendan C
    Brendan C
  • Who's Online   4 Members, 0 Anonymous, 983 Guests (See full list)
