74l Very Rough Idle And Dropout At Speed, 99 Suburban
gf235
1999 K2500 Chevy Suburban, 7.4L, 193K miles
Replaced head gaskets over weekend and while engine starts and run, it is extremely rough at idle w/ tendancy to stall. At highway speeds, it will operate fine and then randomly feels like its shuttung off for a portion of a second. No codes.
Troublshooting:
1 - Checked for vacuum leaks (w/ WD-40), checked connectors and shook harnesses to try and cause dropout - no issues
2 - R&R'd: FPR, IAC, plugs & wires, rotor, cap - no change in symptoms
I see this is a common porblem for 7.4L's but have yet to find a thread where the problem gets solved. Would appreciate any troublshooting advice. If I take this to Chevy dealer will their engine analyzer have a good chance at isolating the proiblem?
Thanks!
Changed filter about 50K ago. The problems at speed are erratic, not constant, so wasn't thinking about the filter but will R&R that and see what happens.
Any other suggestions appreciated. Getting ready to punt and take it chevy dealer and hook up the analyzer.
It's a 1999 with timing computed by the engine computer, if there's a way to check (or even vary it) I'd do it, but w/o an analyzer not sure how to. It does seem like a timing poroblem but that's just guess, and so far my guess have been wrong and cost about $500.
I said check the distributor INSTALLATION for correct timing, meaning make sure you are not a tooth off. The computer can't compensate for incorrect install, make sure the base timing is correct.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
