Power Window Upgrade
Hi, i have a 2001 sierra, I am looking to add power windows to the truck, that was the only option that it didnt have that i wanted when I bought it. Now if i find a parts truck, will i be able to get away with swapping just the inner door panels and the motor/regulator assembley or do i need to change the glass and door too? And im assuming that the wiring would be pretty srraight foreward but I would apreciate any advice frome someone who is more experienced in this than me.
probably a whole lot easier and cheaper to just use an aftermarket electric window kit. any decent alarm shop chould be able to do it.. my neighbor has a 1986 Chevy Silverado that he added them too, been working for him for over 15 years without issue..
it's basically a little motor that replaces the crank on the door panel, and uses the hand crank gear and hardware.. about $200 installed most places.
but if you want to do it OEM, here is some info for you:
http://www.a1electric.com/silverado2.htm
the kit:
http://www.a1electric.com/Merchant2/mercha...uct_Code=GM83-K
the wiring and switches (not included in the kit)
http://www.a1electric.com/switches.htm
