Tranny Fluid Question - Ok To Mix?
I have an 08 Burbon and I plan on draining the fluid and replacing the filter. I want to switch over to Mobil 1. If I am dropping the pan and filling with Mobil 1, is it going to play nice with the stock Dexron VI in there? I have 40K on it with little to no towing at all. I plan on doing this every 30K or so.
I think you will be just fine doing that.
Why don't you just get dexron V1 in Mobil 1. they make it. I would not use the Mobil 1 one size fits all.
Dexrin V1 is a spec not a brand.
List of people who are licensed to make it..
http://www.imakenews.com/lubritec/e_articl...5.cfm?x=b11,0,w
^what he said^
my original answer assumed that the correct spec fluid was going to be used
