At very minimum I would give black bear a shout and get tuned
Sent from my DROID RAZR MAXX using Xparent Red Tapatalk 2
My truck blocking the 300 yd range for the mower. And another on the way to the lakes with my buddy.
Sent from HTC's "too hard to implement ICS" Inspire 4G running JB
@Sarahsgmc
Been out for a while..You've done a lot to your truck since (lift, tires) I've seen it last..
Looks good.
@sarah - clear them corners already!
Sent from my SGH-I927 using Tapatalk 2
2013 Silverado LT 5.3
IPCW LED Tail-Lights
IPCW LED Mega 3rd Brake Light
GM Summit White mud flaps
Super 44 Flowmaster w/ dual exhaust
Spyder Projector headlights(on the way)
Westin Ultimate Bull Bar(on the way)
10,000K HIDs- Low beam and fog lights
Edited by SummitZ71
Took my boy fishing yesterday, got a little dirty getting there.
I bet those 20's really hindered you offroad. :P
    Tonwantonga
    Tonwantonga
  • Who's Online   5 Members, 0 Anonymous, 622 Guests (See full list)
    • Heat is what kills them, the redesigned cooling system and that full temperature thermostat on the side of the transmission doomed them from day 1.  The heat eventually causes the clutch material on the plate to flex which then breaks up and runs throughout the transmission.     The GMT900s when serviced regularly, often run into the 200K mile range or more.  One 6L90 in an HD3500, pulled into the shop on its own power for overhaul at 320K miles at Precision Transmission a few years ago.
    • Nice! And thanks for the assurance I'm helping Pepper and not hurting her. 😉
    • I started doing this late last year as a habit and situationally for much much longer. Coincidently I've found 1500 rpm to be my trigger point as well.    It's the same sensation as a manual held in high gear at low speeds. You can feel it tearing itself apart. Don't let it!    I'll add this tidbit. When on a longer run at 50-55 mph and in M5 once up to speed I tap the tow button which will hold it in 5th gear and then ask for M6 to activate the AFM. When I have to slow to a speed that will downshift I go back to M5 then tap out of tow. Smooth as butter. I still use D for Interstate work above 54 mph. If I forget, it will remind me. LOL.
    • Thank you Phil 😉    https://uscommodityprice.com/difference-between-spot-price-futures-price/   Read the entire article but pay attention to the paragraph on 'Convergence at Expiration" and how the futures telegraphs the spot price. At delivery they are the same. Pump price responds directionally to the futures price. No they are not the same but at delivery they are indistinguishable. Good thing to or you'd be paying a thousand dollars a gallon for the stuff.      There is an definitive answer with an absolute and assured result. However that answer cannot be discussed on this site.    But I can say this. It is beyond the ability of any human or any group of humans no matter how well meaning. We have had thousands of years to prove we could and the results are dismal. Until then we have this:         And there it is.
    • I had a strange problem with my Avalanche. Yearly once the temperature started getting hot. It would freeze me out going to my walking trail about 8 miles. Nothing but hot air going home. My machanic would put the Freon in the machine vacuum the system. No leaks put the Freon back, good for the year. My brothers truck wouldn’t work at all until he did the same procedure. I believe he finally changed the expansion valve to solve his problem.
