Where do you start...
elboberino
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Roof.
I wash from top to bottom.
I'm the same as Tom!!!  I want the dirt to flow off the top and then down.  I don't want to have clean sides and then let the dirty water from the roof flow all over the just washed areas.
I do tires, then wheels first. Then I start at the top and work my down.
Same here.
Kinda off topic, but I also have 3 brushes to clean the vehicle...
1 for rims/tires
1 for body/bed
1 for undercarriage
On the car I do roof and trunklid, then move onto drivers side, rear, passenger side, and finish it off by doing the hood and front end.
I do it the same way everytime and I'm not sure why :chevy:
Roof.
HUH?  I only washed my roof maybe twice this yr.  I waxed it once  :chevy:
I start with the front windshield then the hood then the front.  Then i work my way on the drivers side.  Finish that side move to the tailgate then to the pass side.
In the summer i do section by section drying each (sun will dry it up quick and leave water spots).  When the weather is cold (like now  :angry: ) i wash it all then dry
Its been a good month since i washed mine last cause the only chance i get is on fridays and the last 3 have been crappy
This fri better be nice
    Smitty462
    Smitty462
  • Who's Online   6 Members, 1 Anonymous, 705 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
