Help Choosing A Hood Deflector
I'm looking for a slim hood protector in chrome. I've seen some terrible ones and would like some advice before I order. I am leaning towards the AVS aeroskin guard. It seems to have a nice tight fit and wouldn't stand out.
Anyone used this model or have any recommendations......
Hi,
I purchased a Stampede Chrome Bug Shield (Model: Vigilante Premium) for my new Silverado.
It's not as slim as you are hoping I guess and yes I think it does stand out. I just got it yesterday and I installed it right away. It may not be what you are looking for but I thought of showing you. I think it looks super. Photo attached. Installing it was a breeze. You simply have to install 3 gromets & screws in holes that are already pre-drilled under the hood. Perfect fit.
Stampede also makes another model called "Vigilante Low Profile". Check out their site.
Cheers!
I personally like the GM hood deflector more than the aftermarket. In addition to perfectly contouring the hood, the quality of material seems to be much stronger. I have owned the GM style deflector on both my old classic and new nbs, and have also installed it on seven other gm pickups.
Heres the factory chrome hood deflector, the installation is really slick with all the holes already in the hood and GM utilizes them for the protector.
I agree. For the GMT900 Sierra you cannot beat the GM hood deflector. It's contoured for the Sierra hood and does not cover the upper chrome strip on the hood like others do. Quality and ease of install is great. Also, there is no noise at any speed vs other models where people report added windshield noise after install. You can also get them colormatched to your truck. I picked up a Fire Red OEM on Ebay for $75 a few months back.
i didnt like the GM one as it did not cover the upper chrome strip on the hood, the reason i got a hood deflector was to protect the hood/chrome strip.
One thing to add that with a hood deflector alot of stones/bugs hit your windsheild.
I went with the AVS aero skin.
Hi,
Cheers!
Ironmask,
Have you got any side views by chance? I have a new HD2500 that the wife has already put chrome door handles and vent visors, not sure if i will go with a bughshield in chrome as well but leaning that way, just dont want it to be over the top.
Hi,
Cheers!
Ironmask,
Hi,
The deflector that 2010LTZ4x4 posted very much resembles the one that I purchased. Note that I did not know that GM made a bug deflector. There's no doubt that GM would guarantee you a good quality product.
I am not an engineer to comment on the quality of the plastic and chrome finish of aftermarket accessories. However, Stampede claim that it is of a high quality and finish and I believe it. But then again, only time will tell. Stampede also make another model which they consider low profile. I personally did not like it as it is too narrow near the ends. For the price you pay for these accessories it should have good qualities, and I feel that If I'm gonna put something chromed, it might as well stand out. I believe that the finish of a chrome accessory will deteriorate faster than a "Smoke" one, but it's a choice that one makes. Either way, I have no regrets over my purchase.
Note that I'm from Canada and the item cost me $158 shipping included. I thought it was a reasonable price.
Cheers to you, and Good Shopping!
AVS Aeroskin are amazing
Thanks for info guys. Ordered the aeroskin in chrome from Summit racing.
How do you guys like the AeroSkin? I looked at one today for a Silverado (they didn't have one for a Sierra) and am on the fence about getting one. I'm sort of leery about the 3m tape used to hold it on.
    Sothpaw27
    Sothpaw27
  • Who's Online   4 Members, 0 Anonymous, 573 Guests (See full list)
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
    • The so called rare failure that some certainly liked to tout ( die hard Ford fan boys ) as per the lifter failing and wiping out the cam. Back when it started happening the blame was being pointed to the lifters and honestly I never did hear anything myself conclusively one way or the other on that. Ford themselves in I believe 2024 had a technical bulletin I will call it that came out and for some engine platforms they were reprograming the engines idle speed but also they had a software update for the oil pump which then some time later was said what that software update did as to be increasing the oil pressure at idle. It is a good question if that issue was completely solved as one Ford specialist mechanic youtuber said he saw failures after that time period. Like anything there would be the variables, what oil is being used and the OCI and how much idle time gets put on an engine. I've seen some comments to claim that the L8T isn't so happy with high idle time either but I also know that companies that require their vehicle to idle a lot on the job don't tend to get the oil changed often enough for all those hours of idle time and go off of the odometer.
    • My 2026 Silv. 1500 WT (reg cab/short bed/4wd) has the 40/20/40 with storage in lower middle seat as well as the fold-down center bolster/armrest.   With the dual glove boxes this is about as much storage as possible in a std cab IMHO. Bill
