Engine Over Heats Only When Ac Is On
sm00thpapa
Check to make sure radiator fins are clean. Same goes for the condenser. Check operation of fan. If fan is weak, lazy or is not locking up then you're not pulling enough air through the condenser and radiator
Put a new fan clutch, water pump and changed the coolant and still over heats when the AC is on. Now when I am at idle speed it idles erratically and cuts the engine off.
Now the engine stumbles at idle speed with either the AC or heat on. What can it be? Please share some advice or if anyone has ever experienced this issue. Thanks...
