Adding Sub To Factory Stereo
Hey guys, so I'd like to get a little more bass out of my stereo, but without the "non factory" look. So what are my options for adding a sub to my stock GMT-400 ('96) radio? It only as a casette play, and no external cd player or security.
Also what would be a good size amp and sub to go with for a regular cab truck, with the goal being to be able to get a decent thump out of it but nothing too crazy.
Thanks in advance
Thanks in advance
Now, I have a quad cab 06 chevy and have me two tens in the back and they sound pretty good, but being that yours is a single cab one of two things, do you have the bench seat or do you have bucket seats, if bench you will have to not mind scootin the seat up a bit if bucket you can either custom mount sub or subs in the center console or buy two separate angled truck boxes and put one behind each seat, being that the boxes are small I would recommend shallow mount subs to put into the box. As for recommendations, I have a Dual truck/angled box for 2 tens, the subs are Absolute Shallow mounts, they beat hard, had kickers in them but they are just too big and sound like crap, and the amp im runnin is an MTX Jackhammer JH300, that amp is fan cooled and has a bunch of features w/ bass knob. Oh also you will spend alot more money staying stock rather than going aftermarket because of the Factory system expansion modules are expensive and take up room. But up to you Good Luck hoped this help.
Here's a simple setup. Buy a low level converter to rca plugs out, use rear speaker wires for input, buy 2 10" woofers with 100 x 2 amp. Make your own box out of 3/4" mfd particle board the length of cab. Make the box sealed with a divider between the two spaces. Measure back of seat angle where you drive at, usually 5" top, 9" at cab floor. Also measure for speaker depth at the angle. Check ebay for converter for stinger or pac.
Ok, so I'm gunna need a low level converter to rca, and then just tap into the rear speaker wires and that will go into the amp? I'm assuming you mean at least a 200 watt amp? Also, I was considering only running 1 sub, would there be a very noticeable difference?
Also, any reccomendations for a cheaper amp and subs, I'd really like to spend as little as possible, but not have a cobbled up set-up either.
Thanks again guys
I cut the rear speaker wires, add to input of converter, output will be rca plugs, add rca wire to amp input. I have heard a one woofer setup, like two better. Yes, 200 watt amp. Check Crutchfield for options of amps and speakers. Later on you can upgrade front door speakers and add another 100 x 2 amp with an external crossover.
I know you said you wanted the stock radio, but if you chnage your mind, I ve got a slightly used Pioneer Ill sell you for $65 shipped to your door. Its not the most expensive one ever made, but its a nice one. I had it in an S10 but decided to upgrade before installing it in my 1500.
Heres the thread of my system i just did http://www.gm-trucks.com/forums/index.php?showtopic=131635
But all you do, what i did anyways. Get yourself a line out converter. Bring your wires from behind your deck into it then run the rca plugs to the amp. Then on the amp you come out of your terminals back to the wires you cut at the factory deck. That way your signal/power comes from the deck to the converter, then to the amp, out the amp back to the wire then to your speakers. Dont need to pull any door panels off or anything. I have a 4 channel kicker 250 watt amp. Pretty easy to do, just little time consuming but a nice look in the end.
So once your speakers are wired up for your upgraded sound you can bridge off your amp to your sub.
amp was on sale for $130 at best buy and a line out converter was $50 and i got the adjustable. Just basic 10awg for your power and ground. I used 16awg for speaker wire which is kinda over kill and just any rca cable with a left and right plug
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
    • Good looking Olds, and TRX!   I haven't been into car shows either. I'm probably not a convert but I did push myself this year to attend a few select events to challenge some assumptions and try to experience car-based social clubs in a different way. I joined up with the local Hagerty group for some cars/coffee events, group drives. A month ago I showed my '94 Camaro I rescued last fall at Radwood. Had a good time, but, there was some sitting around with the car and that's the part of shows I don't enjoy as much. I prefer to be a spectator, walk the show, grab a burger, go home.   Radwood was the only era-limited event, but where it had strict model year limitations, it made it up in variety. Having Jason Camissa there was also a hoot.   Where I see old 50's car shows, doo-wop and winga dinga music stuff fading out, same with "only" vintage muscle clubs, it seems to be the activity-based clubs/events which are gaining strong popularity. Places where all cars and interests come together.
