Wheel And Tire Combo
White96Z71
Hello everyone. I'm looking to get a new set of rims and tires for my 96 Z71. First question, I want my truck to have a wider, more agressive stance. Kind of like the 2500's. What size offset wheel should I look into getting? I'm still going to leave the rim size at 16" though. I was wanting to go with 31's more than likely. Which leads me to my second question. I was going to crank my torsions in the front for extra clearance, and for the rear I was thinking maybe the add-a-leaf? Do you guys think that would give me enough room to comfortably run 31" A/T's? Thanks! Pics are welcome of anyone running 31's with stock suspension! :thumbs:
im not sure about the offset but i belive stock size was a 265/75/16 which is pretty much 31s. so you should have no problem running them.
you can still get away with 285/75/16 with out much rubbing also if you wanna go wider which will might cause more rubbing will be a 305/75/16. But with my 98 before i jacked it up i had those 285s on
