Fuel Economy Problem
Hey, i have a 2004 Silverado half ton truck with the 5.3L engine in it. I have added a 3" level in the front and a 2" rear block. I put on 285/75R16 Cooper STT's when i got the truck. My engine light was on and i was only getting 9 mpg. i got it scanned and it pulled up a code for the oxygen sensor onces and max air flow. They told me to replace my max air flow so i did that and replaced the air filter too. Now i am getting 11 mpg which is still terrible. Does anyone know why i am getting such bad fuel economy or how i can make it better!? Thanks
Did you program for the taller tires cause the math will be off if you didn't leaving you to believe the mileage is worse than it is. Also what gears do you have in the truck? If you have 3.42 or worse, thats another reason your mileage is suffering.
I had an 03 5.3 with 4.10 gear and 35" tires and still got 13-14 in town, 18-19 highway.
Yep, that little lift & bigger tires is probably the problem. You're driving a brick on wheels. I had an '06 with the same setup, and 3:42 gears. I averaged 12-13 mpg driving pretty easy. When I drove it hard, it got around 10-11 mpg.
I have the 3.42 and I get great gas mileage. 19 city/hwy mix and 20-21 just hwy. :)
Look in the glove box for the RPO codes, GU6-3.42s, GT4-3.73's, and GT5-4.10's :)
Also G80 is factory lockers.
That's because your truck is stock. When you add a lift and bigger/heavier tires, the 3:42's suck.
I have the 3.42 and I get great gas mileage. 19 city/hwy mix and 20-21 just hwy. :lurk:
Ah, that makes sense. Good thing I have no intention of getting a lift or adding larger tires. Thanks for the info. :dunno:
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
