Undercover Swing Case
hmm i wonder if these would fit my 06 .. It couldnt vary that much i dont think..
I've talked with undercover to see if I could convert them to work on my new one. The boxes are all the same but the brackets are different between models. If you have 1/2 inch by 2 at the back of your bed then the swing bracket should work fine. The latch bracket might need a spacer/trim depending on the side of your bed.
I checked and they show a different part number for 06 than mine for 95. I have a buddy with that style, let me see if I can take a look at his.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
