2001 Gmc Sierra 2500
Thanks in advance for the help guys. I just got my first 2500, Ive had several half ton trucks and Suvs but never a 3/4ton untill now. I have a 2001 GMC Sierra 4x4 2500 not the HD version with 56kmiles on it with the 6.0 automatic and 4.10 gears front and back and when I apply the brakes quickly the pedal will pulse about 2 or 3 maybe 4 at the very most almost like its bouncing back in a way. This doesnt happen when I step on them normal only when I step on them to stop fast. It does have the tow package and I installed a brake control into the factory hookup but this was happening before I did this. Im lost, almost makes me think its something to do with the ABS but Im getting no codes. The only place this can be felt is in the pedal not the steering wheel not the seat or floor nowhere but the brake pedal.
Rotors and calipers are still the original from the factory, I forgot to mention the truck only has 56k miles on it even though its an 01'. The calipers dont stick or drag, the rotors are not warped or at least nothing is being transfered through the steering wheel or brake pedal that I can feel. The pads look to be fairly new probably changed before I bought the truck. I dont think its an ABS wheel speed sensor issue but I dont know for sure, its not related to speed but more to how fast the pedal is depressed. Its will do that weather Im driving 50 or 5mph.
This sounds like what my 00, 2500 would do. It's kind of a quirk of the hydroboost. I'm not sure if my current 3500 does it, or if I just don't notice it anymore.
Mark
Every truck I've driven with hydroboost (4+) does the same thing. When you jump on the brake pedal quickly, it bounces back up at you. Thats just the nature of the beast, nothing wrong with it as far as I know.
Thats good to know, I was sure dreading trying to trouble shoot this brake system. I didnt figure it was the ABS, different feel to that kicking in. Now I can relax a little about it. I guess Ive gotten used to it now because I rarely notice it now.
My 08 GMC 2500HD Dura did the same thing. It is the nature of the rather poor brake system used prior to 2011. When applied quickly, the brakes appear to be doing an ABS shudder.
My 2011 Silverrado 3500HD Dura is a totally different ride. The brake rotors are 14in all around, larger thicker rotors, larger calipers. There is more brake boost, the calipers are preloaded and engage instantly with no brake pedal slop. The suspension and brakes in any 2011 GM HD are the difference between night and day as compared to any pre-2011 HD. For any of you that have not driven a 2011 HD you should treat yourself. Most 2010 and before GM HD owners would not know any better unless they have actually driven a 2011 HD.
I've got 56k on my 06 GMC 2500hd and I noticed the same thing. I thought i was crazy because this is my first 2500 too and my 1500 before this did not do that. I haven't really noticed it since I installed a set of braided stainless steel brake lines all around. What a world of difference.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
