Drivers Side Window Switch Problem
Does NOT happen every time, when I first start my truck and go to roll the drivers side window down, it doesnt immediately go down. The switch doesnt react for about 10 seconds, sometimes 15 seconds, sometimes 5.
The drivers side is the only window this happens on, and it seems to happen worse on hot days.
What do you guys think ??
-matt
-matt
-matt
I would start by checking the switch connections and cleaning it.
It will be the wire loom from inside the truck to the door switch, I have changed everything on mine and still have no up down on drivers side. Dealer told me it is cheaper and easier to just replace it, but for the 99 that part is no long available!! :banghead:
On my 07, the driver's door glass will not go down for 5-10 seconds after I start the truck. It has always done that - but I don't know if it is by design. It has never failed to work otherwise. I just got used to it.
Edit: I never have timed this, but after a few seconds it always works fine. It seems consistent, so I figured it was just part of the operation.
my 07 silverado did this. They replaced the switch and it still did it. Traded that truck in for my 2010 and that does it too. It only happens on hot days. I just live with it.
