Trailer Light Wiring...
wotexva99
The wires from my harness to the 7 pin trailer light hook up blew on my 01 1500HD. I bought a new 7pin hook up but the wires do not color match. Does anyone know what what color wire does what?
Ex red wire=power white=ground etc etc
Thanks!!!
Don't know if this will help you or not .. because I believe you have the separate yellow turn signals on the '01? I can't remember.
But anyway, universal colors are usually:
Blue for trailer brake
White for ground
Brown for running lamps
Yellow for left turn
Green for right turn
Check this out: http://www.etrailer.com/faq-wiring.aspx
Just a note that GM changed the wiring arrangement on 03?
and up full sizers so its best to use a tester to verify.
Heres a note from the site link posted above:
Vehicle manufacturers have intermittently changed wiring colors over the years.
It is recommended that a circuit tester be used on the tow vehicle's wiring harness to verify that the correct wire has been located for the proper function.
Ask me how i know.................
^^^ Yep, +1. Good tip.
Thanks!!!
Scroll down to the 7 pin plug. Maybe this will help!
