Put 285's On The Truck...what To Set Psi?
BUDMANZ71
Well I finally got the 285's for my truck. I ended up with the nitto terra grapplers. Now when I got my truck the tires were set at 35 PSI. I've been told by a couple of buddies that I should set them around 45-50. I have the E load tires. I would put pics up but some 18 y/o decided to go under my truck with her "graduation gift" ford focus so it's banged up in the front :) Thanks in advance for the replies :)
Thanks a lot guys. I thought it was a little high but I guess not :)
I run 40 all around on my current load range d tires. Never had any issues.
I just replaced my Michelin AT2s in load range D. I had them at 42psi since the day I got 'em and got 70k out of them. I could have gone another 5k, but I really wanted the BFG AT KOs.
This..
It would help to know your model of truck and if gas or diesel. I had those tires in 285-70-17E on a 2008 GMC 2500 Sierra Duramax and they only lasted about 25K to the wear markers and I pulled them at 30K. The diesel truck is very heavy on the front axle and lowering the tire pressure too much will cause
sidewall flex in turns and heavy breaking. My tires were rotated every 5K by America Tire and I esentially hauled nothing.I ran my diesel truck at 60LBS all four.
