Is This A Stepper Motor Problem
hmichaud
2005 GMC 1500HD 4x4 QuadraSteer
A couple months ago the digital display would randomly reset all the trips, averages, engine hours, etc.
It seemed to happen most often when the blinkers were used, and the display would read "turn signal on".
Then the mileage jumped from 114K to 989,xxx before freezing, and then displaying "error".
It has been this way for about a month, also all the trips and averages remain at 0.
I haven't had any issues with gauges, speedo, fuel, or with the lighting of the display.
If I have the stepper motors replaced, will it fix my odometer "error", and will the true mileage be displayed?
Thanks for any help you can provide.
  • 1 month later...
I have a similar problem, my gauge shows 330,000 miles and a mechanic told me there is no way that this truck has that many miles. He has heard of clusters adding miles like this, he told me to call the GM dealer to have them inspect and reset mileage. They had no idea what I was talking about when I called.
Does anyone have a similar problem or heard of speedometers adding miles??
Thanks!
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
