Where Is My Engine Oil Going?
It can still be burning it and not cause any noticable smoke. I would get someone to follow me around town for an hour or so and have them watch the tailpipe. My best guess from god knows how many thousands of miles away is valve seals. Watch for smoke on deceleration or small puff of smoke on hot start up.
probably into one of 1,000 oil consumption topics that are currently going on :rolleyes:
haha actually laughed out loud at that one :cool: Its getting almost as bad as some of the Honda forums here now lol
My 2005 did the same thing. Mine was an aluminum block, 310 HP, HO, L33. Started using a little oil at very low miles. No leaks, never any noticable smoke. By the time I hit 100k miles it was using a quart per 1000 also. I just added as I needed it and chocked it up to a characteristic of the new aluminum block HO engine in 2005? Didn't matter what brand of oil I used or regular dino or synthetic. My brothers 5.3 iron block never used oil.
it's possible your PCV valve is bad. letting more oil blow by than the "acceptable oil consumption" by GM
take your intake tube off, open the throttle blades and look inside your intake with a flashlight. chances is are, oil is built up inside the intake manifold. if so, go get some seafoam spray and a new PCV valve.
for reference, my 98 dakota consumed a quart every 3,000 miles, but it was from something else, not the PCV valve. i started using Lucas oil stabilizer every oil change and the oil consumption stopped!
lucas oil stabilizer= baaad....look up the videos online, it makes the oil foam and lose its lubricating propertys i recall one video where once the stablizer was dumped in, the oil couldent even climb gears
Hmm- a quart every 1000 miles is a lot. I had a 97 VW Jetta diesel that went thru oil like that, due to a leak on the rear main seal.
It could be a characteristic of the Alum. block motors......
If valve seals are bad, have someone check the tailpipe on cold startup, as that's when you'll notice the puff of blue smoke. That won't account for a qt every 1000 though.....
Maybe it's a combo of leaks, valve seals & consumption.......???
His 2005 has a fixed orifice PCV valve. it is made in the valve cover and is not replaceable. As to the oil stabilizer...I have never purchased any oil that needed stabilizing.
http://www.bobistheoilguy.com/forums/ubbth...733#Post1831733
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
