96 Jimmy 4.3 Swapped Motor Now No Battery Power
ok helped a friend swap motors in a 96 jimmy now after it seems that every thing is hooked up and stuff we have no battery power. turn the key and not a light turns on. i hooked a meter to the alt case and then to the battery + and show 12v so im grounded but when i check for power on the drivers fender dist. block i get a neg instead of a pos. anybody got any ideas?
  • 6 months later...
Check the ground strap behind the motor on the pass. side. These ground straps often get forgotten and will wreak havoc on everything electronic. Wont hurt to double check the one that goes from the battery to the block also.
