Chevy S10 Difficult To Start
nmiller90
I have a 1991 Chevy S10, 4.3L that has been having some trouble starting lately. It's very sporadic when it does it, but when it happens, if I hit the gas it will start, but it will shake horribly until I let off the gas, when it will then stall out. Then, if I let it sit there for about five minutes or so and then I try again, it starts just fine. When it stalls out, the check engine light will come on. So I checked the codes, but all I'm getting is Code 12 over and over again. I thought it might have been a spark problem, so I changed all the spark plugs as well as one of the plug wires that was bad, but that didn't help. I also changed the air filter, cap, and rotor as well, but that hasn't made any difference.
So my next thought is that it could be a sensor problem, but I'm kind of short on cash and I want to avoid throwing unnecessary parts at it. Anybody have any thoughts on which direction I should take this?
UPDATE: So I messed with it some more and finally got a code reading. I got Code 33, map sensor voltage too high. I talked to a mechanic and explained the symptoms, and their guess was the fuel pump, or something similar that is causing low fuel pressure. That seems plausible, but my next question is can a bad fuel pump cause the map sensor code to go off?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 0 Anonymous, 909 Guests (See full list)
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
