Have a 2006 Silverado , 5.3. push button 4 wd, when engaged in any 4 wd settings my indicators light does not come on, checked fuses, what do i need to ck next.
Thank you.
Thank you.
ok, well thank u any way.
Thank you.
Bulb behind the indicator could have burned out.
Thank you.
i am guessing it would be a pain to get too?
I wish my 2011 has some type of indicator as to what mode your in . Its only on the little dial and not easy to see . Why didnt they put something on the dash/speedo area with all the other gadget lights .
Your talking about the lights on the switch itself, correct? I don't think they had any lights on the dash. I would say you would have to replace the switch.
The GMT 800s and 900s did not have lights in the dash, only on the switch, with the exception of the W/T models with the manual 4X4 lever on the floorboard, those had lights in the dashes.
Thank you.
So here's a silly question (my truck has the same set-up - little indicator lights on the button itself)...
Does your 4wd actually engage, just the light doesn't come on? Maybe the light is a response to indicate the 4wd is actually engaged and yours isn't hooking up.
Just a thought.
Thank you.
Just a thought.
the 4x4 indicator on the dash, not the button, might just take it in.
EXACTLY. You may see what you think should BE a light on the dash but there is no light behind it, there is no socket in the dash for that light. The only light is on the switch itself.
  • 5 years later...
I have a floor shifted transfer case, 4x4 works, but the dash light that used to light up indicating the front axle is engaged does not come on now. Is there a sensor for this on the t-case??
Sent from my Nexus 7 using Tapatalk
    • They are talking about adding more tax to our fuel across Canada by the labour day time frame, its the carbon idiot tax increase on top of the pile of fuel taxes we already pay thanks to the WEF dictatorship running the country. 10 cents per liter on gas and 4 cents a liter on diesel I believe is what was said. That is a huge amount of a tax increase as its another 38 cents equivalent to a US gallon of gas. The reason our fuel is higher than the states already is because of of the high taxes they have imposed on fuel.
    • This is just a thought as I can't claim this is the correct thing to do but will suggest it and you can decide if its something you would try. First round up some electrical contact cleaner spray as they at least claim its not supposed to damage the components ( brake cleaner depending on the type is a real destroyer of plastic etc ) and to use that to assist to clean out any grime from the pins as well as the mechanism by spraying and working the lever etc. Then my next thought is to use silicone spray lube and not on the pins but on the seal and the pivot assembly. It may not be possible to spray it on certain area's and have to use a q tip as Davestar mentioned to keep it from getting on the pins. Dielectric grease can be fine on some things but its easy to get too much on if not careful and then gunk things up and a possible risk of getting it on the pins or sockets. The silicone spray is able to get into a mechanical component to help lube and on surfaces its just a fine film to reduce friction such as that seal. Also it can be doused off with a good flush of the electrical contact cleaner the next time for a repeat of a "clean and then lightly lube" step process to wash off any dirt that had stuck to the exterior etc of the plug.   Free advice, yes. Good advice ... now there's the question mark !
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
