Factory Dash And Door Wiring Questions
im trying to add power windows and power locks to a 08' 3500 w/t ext cab d/a,,i would also like to add a factory navigation radio,,i have a complete donor truck with power windows and locks[rolled]
1.what are the part numbers for the correct dash and door wiring harness?
2.can i use the BCM from the donor truck and change the VIN using a tech2 ?
3.to add a factory nav bose radio ,do i need to add a center console or can the amp go under the dash?
so nobody has any ideas ?
Not sure of the door harness part numbers but there are two types and your going to have to get the proper harness for the switches you have , the true truck hard wired switches or the data bus switches each has there own type of harness
I would try and add the power windows to your bcm with the tech II and TIS web
my amp for the Nav is under the passenger front seat, if its a factory nav it does need a amp to sound the way it should
you can use a Pac AOEM-GM1416 to hook the amp and radio together and retain your stock wire harness in the truck
