Luckiest Man Alive
silverado man
I have a solution for coffee.   Just have a fully loaded Tractor trailer full of gravel in your lane on a blind curve at 50 mph at 4:30am in the morning. On my way to work this morning a young rookie truck driver was in my lane on a blind curve and by yhe time I reacted he had hit my side mirror on my truck. I feel soooooooooooooo lucky. The area I was driving in is known for deer so I was probably a little more conscious than I might have been on another stretch of road. It did dent in the door when the mirror was forced back into it but other than a few scratches down the side of the truck and the stain in the seat its not that bad.  The mirror looks like someone took target practice with a shotgum      My guardian angel must have been by my side...
Sorry to hear that.
Same thing happened to my wife a couple weeks ago, except the guy in the box truck didn't stop.
bassdog
SIUME99
He acted like he didn't know he hit me until I turned around and ran him down flashing my lights. Once we talked he admitted he was in the middle of the road. Got my estimate from the body shop yesterday and it was $1250. My insurance company is State Farm and man are they great!!They are quick to respond and they are going to go after the guy for my deductible and their money. This is the first claim I have had in 19 years of driving so I was a little skeptical about how the process works. State Farm seems to be 1st class.
Thanks for the support!!!!
I can get my mirrors painted now.  White
Glad to hear your ok !  Some thing similar happend to my brother several years ago he matched mirrors with a passing truck !  The other driver didn't stop ,  but like you said aside from the stain on the seat :0  the damage was under $50 Cheap mirrors on an old dodge.  We all need g/a's like you must've had that day.
Wow.. Sorry to hear about what happened..
Glad to hear your okay..
I hope i dont have this to look forward to since i m one of those "YOUNG ROOKIE TRUCK DRIVERS" ???
Glad to hear the insurance company is treating you like a human as well !!!!
Wow, Sorry to hear man, I bet that was a frightening sight! (PS, sorry I just got to this thread, I'm just slow :D)
Too bad there are some Truck drivers out there who give 18 wheelers a bad reputation. There are some out there who probably have no business driving a Big Rig. But the same can't be said for all of them. There are some dang good drivers out there.
Steve, I hope you become one of the best. ;)
    • Can anyone explain why the oil pressure runs higher after the DFM is shut off?  just installed the Pulsar Lt.
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
