How often should I get my truck aligned?
I've got a 2000 Silverado 1500 2WD standard cab short bed
85% of my miles are highway.
I know most of what causes an alignment is not milage but the quality and terrain of roads traveled on.
So what I guess I'm really wondering is... what is a good way to tell that it's about time to get an alignment?
I mean, all cars will pull a tiny bit in one direction or another- even when they are brand new 0 miles, straight off the lot.  But at what point does it warrant the cost of an alignment?
Is there a rule of thumb, like if you can't take your hands off the wheel on a level road at 40MPH for more than 3 seconds.. you need an alignment?  Anything like that? ???
Thanks.:chevy:
Well, you posed a good question where most of the old "rules" don't apply any more.  I wouldn't take the following as steadfast rules, just my current opinion on how I would.
Front bearing repack approx every 12K miles.....sealed bearings they don't get repacked, just replaced average at 100K miles
Drive with hands off the wheel of a determined time....most all paved roads are crowned with new car alignment bias for the right lane.  Too many inconsistencies in road surfaces from one section to the next.
So what left of when to do...
Suspension work front and/or rear, including shock replacement.
Tires abnormal wear
If drifting is a LOT more noticable, probably would match abnormal tire wear and a slight decrease in MPG on the highway.
Oh... once every couple of weeks :chevy:
Seriously, Sears will give you a 6-month guarantee on an alignment and check it for free :thumb: .  I usually check back before the 6 months runs out for a free line-em-up.
I look at it this way, as long as the tires seem to be wearing well then all is cool. I keep my tires rotated every 6k and I got 70k out of my set of BFG All Terrains. In that time I had the front end aligned twice. Perventive maintenance is well worth it.
Had an 88 Beretta and never had it aligned, (lucky I guess) and it had 88k on it when I got rid of it and the factory tires lasted me 50k.
Like real estate where it is location location location
IMO, I feel  rotation rotation rotation. :thumb:
Ditto To Black02:
Align only when your wear pattern looks strange, you pull pretty good one way or the other or you obviously knock it out of alignment.  OTHERWISE?  Rotation...robably the most overlooked maintenance item.  Proper rotation and you can milk all the miles out of your tires!
Rotation is key as noted above.  The tire shop here says get an alignment every 12k or 1/year.  Fortuantely they have a package, which I got.  Obviously if you're pulling 9 ways to Sunday, get it checked.  I wish our city would do so for our cruisers, but I guess they'd rather replace tires every other month.
Every once in a while i'll get an alignment when I get new tires (sometimes you can get a deal for an all in one package, tires, mounting, balancing, and an alignment) but if I see no unusual wear I dont get an alignment. IMO I think you would need one everytime you take it to get an alignment but rotation makes up for it.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   3 Members, 0 Anonymous, 453 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
