Bluetooth Music Streaming Questions... Vcim...
so i have a 08 silverado ltz max. its got the bose system, onstar, 6disc (not nav) etc...
im thinking of buying the VCIM 20829984 to get my blackberry to work with the onstar mic and buttons.. i understand if i buy this part, the steering wheel buttons and mirror buttons work, my phone will pair with the truck, and work through the speakers. i know onstar wont work anymore.
some questions i have are:
can i stream music from my blackberry to my truck? and if not any suggestions on what i should be doing instead? because for me to spend money on this project, id like to have both phone and music streaming capabilities. just one isnt enough to make me go through the hassle.
and will caller id show up on DIC or the stereo display?
ive read a number of topics about people changing out their VCIMs and getting phones to pair up and calls to work with the stereo speakers, but never a mention of streaming music.
Thanks guys
Justin
no the GM Bluetooth is hands free only, it lacks the necessary programming and hardware to stream files or muisc (it will not sync your address book)
on my 2010 outbound calls show on the DIC if you use the GM Voice Dial, if I dial direct from the phone it does not, and inbounds do not.
Really? My 2011 shows outbound and inbound and I only make outbound calls from my phone as I can't get the truck to understand me usually. :cheers:
well, does anyone know of a way i can get both options? is there a newer vcim or part from a newer GM?
Not oem. Gm doesn't have Bluetooth music streaming for the trucks. Or any car far as I know. I just had a 2011 CTS for a rental and though it has a hard drive the bt was only hands free.
Only way I know of is with a Bluefusion aftermarket unit.
Walt
www.adcmobile.com
Walt
www.adcmobile.com
That looks like it would do the trick, however i dont have the nav stereo. just the 6 disc changer and bose system.
how does it install?
does onstar still work?
will the caller id appear on the DIC?
explain how streaming music would work and how the calls work when they come in or go out, what buttons to press etc...
id be inteested in purchasing one of these from you. pm me the price if you dont mind.
Thanks
A2DP is the music format, if it supports A2DP it should be able to accept streaming music and play it on the stereo... to answer the last post.
Walt
www.adcmobile.com
Thanks
yeah I was viewing it from my phones browser and the writing was rather small, didn't notice the last line until I got on a computers full browser.
Walt
www.adcmobile.com
Thanks
The Bluefusion will plug and play on just about all 2007-12 GM radios, navi or not. It is about a 15 minute install that you can do WITHOUT TOOLS. It plugs into the XM tuner behind the glovebox with a T harness, and all you have to run is the mic.
It will do caller ID on the deck, not sure of the DIC. OnStar and all other functions will still work - it uses one of the XM bands for display and audio. A2DP is pretty flawless and it plays through all the speakers in the car, so it really turns the deck into whatever source you play on the smartphone or iPad. Volume can be controlled from the phone and the deck.
It will only pair to one phone at a time and will not do phone book display, only call lists (missed, rec'd, etc)
Here's the owner's manual. If you're thinking about this unit, you really should read it pretty thoroughly to make sure your phone will work (it has a couple restrictions) and that the controls are as you expect.
We sell it for $260 plus shipping, but there are some places online that advertise it for way less. Be careful if you buy it elsewhere though - the older units had the brain and harness sold separately, and I suspect that the cheaper sellers don't include the harness. There was also a pretty major software update in the new units, so it really doesn't make a lot of sense to buy the older stuff...
Walt
www.adcmobile.com
Inbound and outbound numbers show on my DIC.
Mine too.
I installed VCIM 20783877 last week in my 08 2500HD Z71, incoming and outgoing calls show on the DIC.
The lady is awfully hard of hearing though ;)
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
    • I wonder how much carbon is on all those high mileage valves?
    • When I had a Bumper subscription for a few days when I needed to run title histories on cars I was looking at, I decided to look up a few of my old/past vehicles.   My 2015 Silverado was still actively registered and it last sold in 2024 with 160k on the clock. No idea if that's on the original engine but someone's keeping it on the road or the original AFM stuff is still going.   It used 0w20. I remember feeding it Mobil 0w20 AFE for the first 30k of its life on <5k OCI's.     Edit: Just did a nationwide search on Autotrader for 2015-2025 Silverados with 5.3's and sorted by highest mileage first.   357k 352k 292k 291k 290k 277k 271k 268k 266k 259k 256k   High mileage on a modern 5.3 doesn't seem all that uncommon, but that's just searching mostly dealer ads on Autotrader. FB Marketplace has all kinds of high mileage 5.3's going back to 2007
    • I can't say I have ever heard of someone getting that type of mileage out of a set of tires even though they rotated on a regular basis but without a doubt if the front end gets wear and those tires are no longer able to track straight it scrubs them off, and driving style and road surface make a huge difference as well.    However that is not what prompted me to comment as it was the new tire theme of sitting in storage waiting to be used scenario. I am sure some tires can last for quite a while in storage if its not too warm and out of the sunlight but unfortunately some tires the way they their rubber compound is formulated they can age and dry out even in a reasonably decent storage location. My brother ran into this maybe three years ago when he was looking at the tires that were on his dually truck and a combination of wear on the rear ones and noticing that the front tires had some cracks around the sidewall of the tire not far from the bead but he had replaced only the front ones not long ago with 2 of the remaining 6 he had left from the initial two sets of takeoffs he had all bought at the same time .... 10 years ago ! ( the years fly by, a truck that only gets used a bit to haul a camper during the summer and sits in a shed for a large part of the year ). That second set of 6 tires, two he had put on the front prior like I said and they had very little wear but those cracks were now present. So we go into the shed where the other 4 tires had been stored all this time and every one of them had the same cracks in the sidewalls and so in the end it amounted to throwing away 6 brand new but 10 year old takeoff tires into the dump that he got a deal on at a tire shop because they aged out. They were a Ford factory equipment BFG tire and those tires did not age well compared to some tires I've seen far older then that and did not show that type of aging. True, they always say up here anyway that 7 years is sort of a limit for age by rights, we don't have the intense prolonged heat that many of you have down in the states that just cook tires and depends on where the vehicle sits when not in use. GB, another words maybe had you bought a set of tires to store it would have been fine as long as you used them up fast enough but there are no guarantees when it comes to rubber, tires or of that other type stored in some guys wallets 😆
