Nbs Mirror Cap
been trying to find paintable mirror caps for my nbs but all i seem to find are chrome :) anyone point me in the right direction ive already tried ebay but no such luck.
You can get them from your dealer,but you have to buy them individually,If you can wait until tomorrow when I get back to the dealership I'll post the part numbers.
Do you have an 05? I bought some paintable ones for my 2000 from performance products .com
Well I have to correct myself :D I didn't notice you had an '05,I thought you had an '07-up GMT900 :idiot:
The painted mirror caps are not available separately from GM for the GMT800 trucks,they are only available with the complete mirror asm.,they ship the caps "loose" for painting,why they do not sale them by themselves I have no idea :lol:
Well that sucks. Thanks for the reply tho
Do you have the link? I never could find these for my 03.
