Popping Noise From Drivers Door
I tried the search feature and couldn't find anything... Whenever my driver's door is all the way open, to the 2nd notch, so ALL the way, when I go to close it, it feels like it is binding on the spring assembly and then will make a popping sound and the door will close fine after that. This only happens when the door is all the way open, if i open it to the first notch, all is well.. By looking at it and comparing it to the passenger side, everything looks the same. Any ideas how to fix this?? Thanks
Mine does this as well. My 2000 GMC also did it
Check the bushing that holds the door open, probably due to be changed. My buddies 07 burban does this too.
You wouldn't happen to know a part #, would ya?? i have looked on rockauto and gmpartseast, i can't find the assembly on there, it has everything around it but yeah..
Thanks
Thanks
I was able to put a mix of grease and liquid wrench on the roller and it seems to have fixed the issue for the time being.. we will just see how long it lasts
    DLZ
    DLZ
  • Who's Online   1 Member, 0 Anonymous, 479 Guests (See full list)
